when i switch on the pinspotter (8270) it cycles one time. problem seems to be in the chassis auxillary board. anyone knows what i have to replace ?
automatic cycle when turned on
Re: automatic cycle when turned on
The aux. pc board is not needed if you have five boards or omega tec conversion. If it upon power up check your ball trigger or if you are using the cycle switches you could have a worn cushion block which could be cycling the machine if the cushion is too low. Maybe there are balls in the pit after open play.
