No Spotting
  • No Spotting
    Ok guys this one has got me stumped. I have a machine that will not spot pins. Sounds simple enough right? Well, I swap chassis...still no spotting. Test Bin switch...fine. Now here is the part that really gets me. I take the original chassis, pull out the XOP Board, put the old 5 boards back in and it works fine. I just can't figure out why it won't spot with the XOP Board. By the way, that board works fine on another machine. Thanks in advance for any ideas.
    Re: No Spotting
    Hey 8270
    That's a good one! Could it be a C-1 pin that sometimes makes contact and sometimes does not?
    I'd look at all the C-1 & C-2a pins & sockets, then the terminal strip on the XOP board. Clean with pencil eraser if corroded.
    It's probably something else entirely. Good luck.
    Choda
      Re: No Spotting
      Chaddie...you have more screen names then a stripper.....lol.....how about those head pin bid guides?
        Re: No Spotting
        Thanks for the tips Chad. It turned out to be the TA1 and TA2 switches being out of adjustment. I have no idea why that would cause a no spotting problem. I just happened to pull on the TA2 switch and it spotted pins. So I moved the switch a little bit, and presto, spots pins every time!
