I have a machine that started interlocking about once a day then it got worst and worst then I found the sweep would intermintly run in reverse at random [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] first I replaced the sweep reverse switch then changed the chassis then the sweep motor then the sweep motor cord still the same intermittent [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] checked wireways for bare wiring and things floating around terminal strips shorting changed capacitors for the hell of it. omega tech boards with nothing hooked up to scoring for a sweep reverse and the sweep will run in reverse from zero 66 270 when ever it wants to. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] CRUD any IDEAS
sweep running backwards
ok guys got a good one for you 8270ss guys.
I have a machine that started interlocking about once a day then it got worst and worst then I found the sweep would intermintly run in reverse at random [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] first I replaced the sweep reverse switch then changed the chassis then the sweep motor then the sweep motor cord still the same intermittent [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] checked wireways for bare wiring and things floating around terminal strips shorting changed capacitors for the hell of it. omega tech boards with nothing hooked up to scoring for a sweep reverse and the sweep will run in reverse from zero 66 270 when ever it wants to. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] CRUD any IDEASif things aren't going right just use a bigger hammer! DIRTTags: None
Re: sweep running backwards
1. I would check the Terminal board on the stator.
2. I would check the Russel Stoll plug. I had a sweep acting goofy 2 weeks ago. Would over run its stops, interlock. Motor was ok, switches ok and adjusted. The russel stoll plug had a bad connection and was hot as hell. Fixed it and no problems since.
Good luck,
Crud,
Did you use to have electical motor starters in the past? If so, some of your wires are changed probaly(this was needed to hold the sweep reverse action work).This is no problem with the Mark 5 or earlyer boards, but if you're using Omega Teck or creative boards(or chassis)you will get the problem you discribed. We've had the same problem on six machines, problem was solved after putting back the wires in the original way.
I don't know the wire numbers and TS connection out of my head but if you want I'll look at it tomorrow.
Succes
BEER
[ November 07, 2001: Message edited by: Lampie ]So it goes.
It sounds like its in the wiring since you changed the motor, cha$$is [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] , and switches.
Time to break out the Block diagram and tester!!!
For a visual check look sooper close at tsa-2,3,4.
And look extra carefull at the bottom distributer side of the C-1 wire plug harness.
LAMPIE
I have solid state switches on all the motors we have national (jap motors) when I switched the sweep and table motors I was hoping it was the motor so I could see if spot pins going backwards
gee I wonder at what point the cups would turn over but it would interlock first [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
it only did it one time today and 6 or 7 times yesterday [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] reminds me of a girl I used to know [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] CRUD
oh AND KING NO RUSSEL STOLL PLUGS THERE ILLEGAL
HERE JUST LIKE A BUNCH OF PEOPLE LIVING HERE.
[ November 08, 2001: Message edited by: CRUDWEISER=BUD ]if things aren't going right just use a bigger hammer! DIRT
CRUD:
This is a longshot, but did you check your C1/C2 cable assy's for stray wires touching there?
You mentioned the Omega-Teks without scoring hookup...did you remove them for diagnosing this problem or are they just not installed? If installed, but unhooked, is there a reversing relay installed somewhere on the pinsetter (front wireway, BE box, etc..)?"Where are we going, and why are we in a hand basket?"
KAT
we have never had any auto sweep reverse or no feel on a strike none of that stuff.
dacos scoring but not for longwere getting twelve strike in two weeks.
I'M with you I think it's a bare wire some place I guess it's time to get the wiring diagram out.
[img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] CRUD
mysterious reversing sweep,I found it :p
KAT AND JIMMY JAM were close
found a wire smashed flat in front of be control box under wireway cover where screw goes in.
the wire was coming from the sweep reverse switch
and it looked like it had been under there for years and finally the insulation gave up.
thanks for all the input.
CRUD
Thats great Crud.
I am curious which wire it was. Looking at the block diagam I dont understand how 1 "shorted to ground wire" can effect a dpdt switch. It should have effected one side or the other??? I bet you have more then 6 wires going to the switch. Do you have a RPO box fore scoring?
jimmy jam
your right there is more wires then normal.the machines came from japan and have extra wiring running all over the place and it was a black wire that was smashed and the chassis all had extra wires running all over the place that I pulled out a long time ago. the chassis also had another relay socket I think it was it was for a automatic reverse on a off spot pin because all the off spot switches had extra wires on them also. it looked like they had all kinds of crap hooked up extra switches on be control box and chassis.CRUD
Quote:]Originally posted by Magic Triangle:
Cruddy-
I bet you've sparked a big interest for Jimmy Jam now - - he has foreign machines also.
Chaddy Cham[/QUOTE]
I only remember the old mechanic telling me that our machines came from overseas...and were modified quite a bit. The pin wheels, distributors, & ball lifts run almost twice as fast as standard 70s (which causes bunches of pinjams and sends clutch operational time before they need to be cleaned through the floor) I can compare since 14 of our 30 machines were not part of the original installation, and run a lot slower. All of the sheaves/pulleys are nonstandard sizes (non-AMF), and I think the gearboxes were modded as well (output shaft RPM is considerably faster than what the book spec is supposed to be). How I got myself into this (or better yet, why) is still a mystery. Sorry... I tend to ramble on a bit... :-)<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Lemme guess - the UL logo on the nameplate has been cut or scratched off too.
Since things run faster than they should, it sounds like perhaps it has 50hz gears in the gearboxes, but I would figure that they would have torn themselves apart by now if that was the case.
Curious, but it gives your place more character.
MAGIC,
your right with the 50hz motors on 60hz power but
usually the motors hold up they just tear the hell out of the machines and the same is true for
14.5 motors also.
but do you know what happens when you run 60hz
on 50hz-cy power. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] CRUDif things aren't going right just use a bigger hammer! DIRT
There's no problem using 60hz motors on a 50Hz net.
Just be shure your table and sweep are having the same type.
The Be is even working better, you don't have to put smaller pully's on the machine to make them relax.
MartinosSo it goes.
