Problem is as follows:
Every once in a while, the sweep fails to raise from 2nd guard. A little flick of SA follower will wake it up.
SA cam and follower adjustment reduced the number of stops caused by this problem, but did not eliminate.
I currently have SA adjusted so that it just barely comes all the way out to 270*, and follower is as touchy as possible. (Max adjustment.)
Still, it will not raise up sometimes.
For lack of any other explaination, I have decided that this sweep is just lazy and does not want to pick it's fat arse up off the deck.
Unless you have any suggestions, mi amigos...
Thanx in advance,
Chaddy-Poo
