converting chassie's to short strike...
  • converting chassie's to short strike...
    I know I haven't been on in awhile, been doing alot of little things around the center and the latest is giving me a headache. I'm converting all my chassie's so my machines will do the short strike cycle and 7 - 10 pin pick, short gutter ball, etc. My problem is this: I have one machine that when I put one of the 3 MP chassie's I have on with the wiring upgrade for the short strike want's to set pins down on top of the pins aready down on first ball. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] When I put a converted 5 board chassie on the problem goes away and when I put the MP chassie on another lane there is no problem. So if anyone has run into something like this I would and know's how I can resolve it please let me know. Oh yea, Mike I've still been reading all the post and still think this is the best site for our business, thanks. Keep it up.
    Joe [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
    Re: converting chassie's to short strike...
    If this is happening with an RPO cycle,check your C2A plug for good connection points for the gripper switch wire you grounded in the machine. (Sometimes connections make good with some machine plugs but not others)
    If this is happening only during a scoring cycle, check connections at the APS plug. You may not be getting accurate signal info from the camera.
      It would help to know how you converted your 5 board chassis's. Do you have Omega-tech or Creative tech. This can help narrow your problem down even more.
        JOE
        I'VE had the problem you describe and I'VE had it not want to spot pins (no solenoid) it's always been a bad circuit breaker on back control most everyone thinks it's just a circuit breaker [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
        I converted a 32 laner from ss chassis to mp and had 5 bad breakers. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] CRUD
          They are Omega-tech boards with the omega tech expander board. The machine works fine with this chassie on but not with the MP chassie from Creative or AMF (same thing, except AMF tacks on about $200 for the chassie.)
            Question. On a regular MP chassis you hook up to the APS plug and on the 5 board chassis you hook up to the pc board. How are you able to swop 2 different chassis around like that? Is there a adapter plug for the 5 board chassis to hook up to the APS cable or do you just run 2 seperate cables to the scrorer? Just wondering.
              There is a adpt. for the chassie. Call Creative Tech they can fix you up.
              [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
              Joe
                JJ
                I believe you splice wires in where you go into the Accuscore chassis.
                  King is correct. There are three wires that attatch to the cable running to the MI box from the scorer. Then there is a plug that connects the board in the pinspotter chassis.
