Jackscrew repair
Tech of the Year 2009
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
Jackscrew repair
Lane 8 was low on the opposite of the ball door. I tore the pit apart and the last mechanic had taken the allen tool out of the jackscrew. I tried to crank it down and level the machine up but it was frozen. I fixed it by taking a 7/8 socke and putting it under the jackscrew. Just lifted up the machine with a prybar and slid it under. Thought I would share this fix.
JerryTags: None
Re: Jackscrew repair
We had a problem something like that... when they installed the new side after the fire, they only used 1/2" and 5/8" plywood under the machines, and after they ran a few months, the legs wore thier way right through the floor. We made spacer legs out of 1/4" steel plate with 1" pipe rings welded to them to spread out the weight a bit. We can raise and lower them by putting 3/4" washers in the bottom of the pipe sections.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Members
- Aug 1999
- 2307
- AMF 82-70 SS Nat PBL Hump
- Qubica/XIIX
- Walker/SanctionSE/PhX
- ProLane/SPL
- 1982
never had one that wouldnt budge usin a 2 foot pipe wrench on the under threads. i had the OBD side of 27 sitting on a 4x4 block of wood. the setting never held and i couldnt find another "stopper". at another center i came across a couple dozen stoppers.
Dutch, I'll try to post it tomorrow. I was going through some stuff from a few years ago and found a bag full with the number on it.
TOON
Sorry Dutch, # on bag was long gone [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] .
[ November 30, 2001: Message edited by: toon30s ]Gene Simmons for president!!!
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- 1982
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
