Dutch
Part #
Re: Part #
lo
ckwasher medium 3/8 951-164-002/??? also lockwasher,spring 3/8 962 500 000
[ January 05, 2002: Message edited by: felix ]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Re: Part #
Are you speaking of the thin shim washer? If so, the item number is 000-029-910. I only install these for emergency use. I use regular flat washers as needed for permanent applications. Hope this helps you....
Steve
[img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]Prevent the problems. Don't do crash repairs.
Drywall in a bowling center: Recipe for disaster.
Re: Part #
Steve,
Thanks, I think that's the one!
You're right, flat washers should be used for permanent applications. The slotted washers are good for quick fixes during league & tournaments. The only place I leave them is at the lower ball lift track bracket. (To prevent yo-yo's) It's almost impossible to get a flat washer to stay in place while you get the bolt thru it. Of coarse, that's only a temp fix too, till I have time to find out what's really causing the problem.
Thanks again
Dutch
