Pins under paddle
  • Pins under paddle
    I have two pairs (PBL) that I'm getting pins stuck under the paddle. It seems like if there is a pin in the door with a ball behind it that the paddle runs over top of the pin instead of pushing it out. Has anyone else had this? The only thing I can think of, is to bend the rudder arm down a bit to lower the paddle in the door.
    Re: Pins under paddle
    If there is sufficient clearance adjust the rudder arm more toward the back of the machine....this will effectively lower the paddle.
      You can also shim the rudder mounting brackets to raise/lower the paddle. Shims at the top bracket will lower the paddle. If there are shims on the lower bracket already, remove 1 or 2 & see what you get.
      Dutch
        Could it be that the paddle has gotten squishy or torn so that a pin can flex it up and get stuck?
          it could be a vantage paddle they were not the right size or shape a few years back.
          CRUD
            As far as the paddle itself, it's fine. Just installed PBL's over the summer. I have the rudder arm adjusted as far back as I can get it without it rubbing the door ring where the rear filler plate would be on a kicker lift. I think I will try dutch's suggestion tomorrow and see what I get.
              I think Dutch has it backwards, shims in the top RAISE the paddle, maybe I read it wrong? Just my pennie's worth.
              TOON
              Gene Simmons for president!!!
                Shimming the top bracket pushes it away and lowers the rudder. Could be that the bracket mounting holes for the casting are worn and elongated causing to much play in the long screw. This would allow the rudder arm to sag. I have replaced some of these. I have also welded a 1/8" plate to the top of the upper bracket and the bottom of the lower bracket and redrilled the holes to extend the life of them.I use a 1/4" inch longer screw and this tightens them up right back to where they should be.
                [ January 15, 2002: Message edited by: Mreessr ]
                  Thanks to Dutch!
                  I shimmed the top bracket and it works great! no more pins under the paddle!
                    GEE NOT ENOUGH BEER I READ THE LAST POST WRONG I GUESS. CRUD :p
                    [ January 15, 2002: Message edited by: CRUDWEISER=BUD ]
                      Quote:]Originally posted by 8270 pinspotter:
                      Thanks to Dutch!
                      [/QUOTE]
                      your rudder support brackets must be mounted on the inside of the sideplates because if you shimmed the top that does lower it.
                      do you have LBS if you do you could run into a problem with the LBS hitting the rear roller pulley. :p
                      the PBL with a LBS the rudder supports are mounted on the outside of the sideplates.
                      but you could have just put a bunch of duct tape on the bottom of the paddle.CRUD
                        Crud,
                        No, I don't have LBS. It's funny that you mentioned the duct tape. I thought about taping a piece of old carpet on the bottom of the paddle, but decided to check here to see what the correct fix would be. Once again this site has saved me some headaches.
                          Glad I could help.
                          Dutch
