Question on Pin Jams
  • Question on Pin Jams
    I have worked on 70C's for 20 years and have always seen this problem. The Distributor has problems feeding the 7 and 10 into the corner bins. It occurs more at the 7 for some reason and am wondering if the is a design flaw in the indexing cam. I have remedied this over the years by changing the cam or reworking the shape of the bin. In the past week, I have seen this about 15 times all at the 7 bin. Everything is adjusted right. Clutch is good and clean, Driveshaft U-joint and balls good, Dist. clutch tension good. Dist belt good. Indexes great All bins parts good
    I don't know if any of you have had any long term observations like this. It seems as though all replacement cams made after 1990 or 91 are not exactly the same as ones made prior to that time. The Dist. to me don't seem to swing as far to left and right as they used to. Maybe each cam is minutely different now due to the manufacturing process.
    Do you think raising the Dist. support up higher than spec is an option. I have done this before with excellent results.
    Thanks for all replies!!!! Jim
    Re: Question on Pin Jams
    we doubled up the spring on the 7 side of Dis on a few of are machines to help them shuttle pins in the 7 and it works
    but ill try that washer fix and see if that helps out better
    Just my 2 cents
      Check out the other thread in this forum, too... there's one there on pinjams...
        as king mentioned, add a washer or two [(depending on how close your front is to your rear) (i'll let you interpret that)] to the rod ending which is bolted into the lateral arm. this washer allows the distributor to exagerate (left and right) the cam pattern.
          Quote:]Originally posted by Coors:
          as king mentioned, add a washer or two [(depending on how close your front is to your rear) (i'll let you interpret that)] to the rod ending which is bolted into the lateral arm. this washer allows the distributor to exagerate (left and right) the cam pattern.[/QUOTE]
          COORS, my front is not close to my rear as I have a BUD belly is that what your talking about.
          CRUD :p
            CRUD :p
            [/QUOTE]
            Nothing wrong with having a good 'shed' over the 'tool'... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
