Here's a tip for you,
before installing a start switch -micro switch . Wrap a it a couple of times with electrical tape before installing it. That way the switch will last longer,as in the brass pins won't work loose, and there is a less of a chance of oils seeping into the switch,also to keep the terminals tight, seal the screws by applying a bright fingernail polish on them, this is so when you inspect them it is easy to see that you have taken care of this switch already.Also only leave the 2 terminals on the switch that are needed,there is nothing worse than having someone put a terminal on the wrong terminal that doesn't know better.
