Ball detector
  • Ball detector
    what is the easiest way to align a Ball detector I spent 4 hours and tried a diffrent Ball detector adn diffrent Mi and still can't get it lined uo I got 20 kines up but not 19 but it will cycle if you hold a reflector right up to it. we have 82-70
    Re: Ball detector
    Sling a snap line from each of your reflectors. Then, looking straight down the line line up the ball detect IR sensors with the line. Ensure that the lenses are clean (free of any lane cleaner overspray residue). Also use the oversized reflectors if you can get them.
      Re: Ball detector
      If it is AMF ball detects you are talking about:
      The original version had small reflectors.
      Call AMF and order the larger reflectors and they will work much better.
        Re: Ball detector
        If it's an AMF ball detector, they have led's that flash when it's lined up. If you still can't get it lined up, then your reflector and the IR sensor is not in line very well.
          Re: Ball detector
          In the middle of the box there are 2 potentiometer
          screws one for each lane, turn the screw until you see the led flash faster.
            Re: Ball detector
            We found all that was wrong was the reflectors were dirty wiped them and the ball dectators off and do the lights relly blink fast now
              Re: Ball detector
              You definately need to keep them clean. Dirt and dust can really interfere with the IR beam and cause all sorts of problems. I usually go through about once a month and wipe mine off.
                Re: Ball detector
                Have you ever taken the TV remote from the front desk and walked around setting off the foul lites and ball detectors. :p
