Synthetic Pins
Synthetic Pins
My centre is contemplating on getting a set of synthetic pins. We are leaning towards the Lane Dynamics pin. Is anyone currently using or had synthetic pins, what is their pin reaction like, what is their life span, and how do thay compare to the original plastic coated wood pin?Tags: None
Re: Synthetic Pins
Stay away from Synthetic pins. They sound funny and they generally don't carry as well. I know a center that tried twisters and pulled them after on day. They flew too high, causing some strange leaves. I would stick the wood pins if I were you.Give me a hammer and some duct tape and I can fix it!
Re: Synthetic Pins
Scruff, I have beeb using the twister for two seasons. I have always used amflites up to that point. Plus side the pin is very durable. I will get 3 seasons out of this pin without rotation. Minus side, the pin picks up dirt, scoring does suffer a little, machine problems with AMF pinsetters. They are not the junk that alot of guys make them out to be but if I had it to do over again I don't think I would have used them.
Mike
Re: Synthetic Pins
We had a couple lanes of Twisters in...for about a day and a half. I hated them, both as a bowler, and as a mechanic.
From the front; the pin carry sucks, lots of weird splits, and when hit, they have a sound akin to tossing a cinderblock into a box of Waterford crystal dishware...or an entire rack of busted wood.
From the back; The coat is slippery and causes more jams, they sound even worse from the back when hit, they cause a lot of OOR's because they slide more instead of falling over (smooth, square bases), and they're also smooth and slippery enough to cause more hangs and 'rollers' in the pit.
Bottom line, I think they suck. Don't get the wrong idea... if they could do something about the sound and action of them, I don't doubt I'd probably like them, but as they are, I couldn't be bothered. Give me Amflites any day.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
