XOP Problem
  • XOP Problem
    I have 82-70's with solid state chassis'. They have just been converted to XOP. I have a machine that when first installed and turned on, the sweep would continuously run. No time delay, no table run whatsoever. We stopped the sweep at zero, then pulled Russell Stohl. When we plugged it back up, the table spotted a rack and sweep went back to zero and stopped as it should have. But, though we thought it was ok, now there is no cycle start at all. RPO relay is engaging when you try to cycle from rear as it should, but no cycle start. S.S. no go either. But the kicker is, put the old 5 boards back in, and machine functions. AMF technical support is mind boggled as well. We have tryed swapping boards and chassis', so please eliminate that from your replies. Thanks. Any help will be appreciated.
    Re: XOP Problem
    I have XOP boards as well, and every now and then they get confused. Try this, turn the machine on and see what happens. If nothing happens and you can't cycle the machine hold the stepper button in for about 5 seconds, or untill you hear the chassis click. This is the system reset feature of the board. It should put the machine on first ball if it isn't already and then the machine should function normally.
      Re: XOP Problem
      I will try that. Thanks.
        Re: XOP Problem
        The problem seems to be in the AIU unit for the scoring interface. Having them swap them around, and will check back in on it again when I find out for sure.
          Re: XOP Problem
          What kind of scoring do you have. If you are using the sweep reverse relay with the board, make sure it is connected properly. If the wires are switched it will cause the machine not to cycle.
            Re: XOP Problem
            I too have these problems every once and a while. Before it was an LIU problem, but when it does happen now I just change chassis and it seems to go away. Most of the time when i pull the boards out there extremely hot. I too also get no cycle nor 1st or 2nd ball. I have tried to hold the stepper button but it has never worked. God i miss MP's..
            deadwood
              Re: XOP Problem
              Does it happen in when put in league play? R18 on the board needs to be clipped because its going into instruct-o-mat. I clipped all mine and have no problems.
                Re: XOP Problem
                Here is my solution:
                Buy 1 Omega Tek board and expander each month.
                Toss all your problem XOP boards in the dumpster.
                  Re: XOP Problem
                  I have qubica in my center and have no xop problems. But, the center that I am in question of here is just a small center with magic score. There is no LIU. It is not going into instructomat. And the sweep reverse relay is connected correctly. And before I installed the xop's, he had some omega tech boards in. All they do is the same as 5 boards. They do not add any functions or eliminate any either. That is why we put these in. Anyone who knows anything about xop's knows that they are a very good system, especially for a center that cannot afford to upgrade to MP's. XOP's eliminate all table wiring and perform like MP's. I have had no problems with any of them in my 24 lane center. AMF technicians could not come up with anything when I called them either. But I found the problem. The AUI unit for the magic score was bad. Hard for anyone to think so, as the symptoms really sound machine related. Thanks.
                    Re: XOP Problem
                    The Omega Tek board does do the same functions as an MP......if you put in the expander.....
                    They are only $150 I believe. The proprietor could save $ by just adding those.....if his boards do not have the posts on the back of the them Omega Tek will upgrade them for free to accept the expanders.
                    The XOP is not reliable and if you check the threads in here there have been many XOP problems.
                      Re: XOP Problem
                      <font size="2" face="Verdana, Helvetica, sans-serif">Thats a good tip DRCS6478. Is it true for all board revisions.
                      <font size="2" face="Verdana, Helvetica, sans-serif">AMF82_70Mechanic, can you tell us more about the AUI unit. What it does, whats hooked into it, where its located, etc..
                        Re: XOP Problem
                        <font size="2" face="Verdana, Helvetica, sans-serif">ive noticed that too. &amp; there are about 30,000 Omega-Tek boards in use. Omega-Tek is definately king of SS machines.
                          Re: XOP Problem
                          The AUI unit is to magic score basicly what the cwc is to accuscore. The machine interface plugs in to it. It hangs on the curtain wall. Thanks to all of you for your advice and input. And King you are correct about the omega tech boards, I was thinking on a totally different plane there.
                          Thanks.
                          P.S. - I have never had a bit of trouble with my xop's. I have 24 lanes of them. Please don't ginx me. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                            Re: XOP Problem
                            No jinx here....Just a big hammer....lol
                              Re: XOP Problem
                              I've had my XOP's for five years now and I haven't had any trouble either. They perform the same funtions as the MP and Omega-Tech. The reason I like the XOP over the Omega-Tech, is that it just uses a simple relay to perform the sweep reverse, rather than another board in the chassis. I think both boards are good and can run for years without any problems.
