Table/Sweep/MTR.Cable Assy.
  • felix
    Re: Table/Sweep/MTR.Cable Assy.
    Old Bowlers & Old Farts; If the shoe fits...
  • TheGMan143
    Originally posted by felix:
    Must a been back in "36", cause now they are $59.84 [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
    <font size="2" face="Verdana, Helvetica, sans-serif">So whaddya sayin'... I'm an old fart? [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
    I resemble that remark...
  • Jimmy Jam
    Kind of reminds me of the C-1 plastic blocks.
  • felix
    TheGMan143
    Member
    Member # 1607
    posted June 23, 2002 01:45 PM
    If I remember correctly, the last time I had to buy a table/sweep mtr plug, I got it from JCP, and it was only about $30.
  • TheGMan143
    If I remember correctly, the last time I had to buy a table/sweep mtr plug, I got it from JCP, and it was only about $30. Not long after that, we bought more machines, and I got a couple more spares.
    If you're going to keep a spare table/sweep mtr. cable assembly around, just get the plug (not the whole cable). Wire it with about 4 feet of SJO 14-5G type wire (Oil-resistant neoprene cable, 14 gauge, 5 cond. w/ ground if you're not sure what that is). 4' of wire will run $5-6, and figure $25-30 for the plug from surplus or a liquidator. If you set it up for a sweep, it can be used in either position without changing any of the connections... just omit the wires not used in the table position, or use 'em all for the sweep.
  • felix
    started a topic Table/Sweep/MTR.Cable Assy.
    Why do the manufacturers charge more for a table motor cable than a sweep motor cable? Just Your Curious Felix. The new table motor cable 070 007 751 has only three wires compared to the sweep motor cables 5. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]HIGH LOW PRICES
    Table motor cable(070 007 751)$167.12-$117.03
    Sweep motor cable(070 005 542)$116.24-$87.18 [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
    Would like to get my hands on the original female plug(000 027 660) for less$$$($66.49-$59.84). You can get NAPA trailer wire(5) for less than a buck a foot.
    When replacing the Table Motor Cable,070-005-543, on older 82-70 machines with the new 070-007-751, Table Motor Cable, you will find the new cable has only three wires. The old cable had five.
    When using the new cable, connections are made: the Black Wire goes to TS-22, Green Wire to TS-20, and White Wire to TS-1A1. No connections are made to TS-13 with the new cable. [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
