Sweep Mounts
  • Sweep Mounts
    Is there a manufacturer that makes rubber sweep mounts for the 70's (070-003-195)? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] The ones that Stahls sells are urethane and aren't as strong and durable.
    Re: Sweep Mounts
    The shock mounts I get from Quality are made of rubber. I order mine through Newells Bowling Supply out of Murietta, CA.
      Re: Sweep Mounts
      If you put the new 090 bracket on your sweeps instead of the slide bar the shock mounts last longer......less sprung weight......
      I havent had a shock moung go out this year....and I havenot lost one 090 bracket due to a ball hitting the sweep either.
        Re: Sweep Mounts
        Most of my machines have the old original AMF shock mounts still on. The few I've replaced are from Vantage and I haven't had anytrouble with those. I bet it's been two years since I changed a shock mount. Not too many sweeps get hit in my house.
          Re: Sweep Mounts
          King: go to your sweep brackets with a flashlight and magnifying glass and look at the top, where the bracket is bent 90 degrees. This is where the first cracking starts. I've had a few break off, but still prefer the 090's. Now if they would just redesign it with the proper angle so the sweep bar would be perpendicular to the lane! [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
