Before I got rid of the pindication, we had a couple problems like that... most were the diodes, as was said (RadioShack has the replacements cheap...they're just standard switching diodes), some were bad sockets... some were broken wires in the cable, which we resolved by running a new wire outside the sleeve and connecting it to the correct terminal. Biggest one with no pindication was the common wire breaking. Others were broken terminals on the chassis side, and all we did is solder a female bullet terminal on a wire to the broken pin base, and did the same on the mask connector, them plugged 'em together. Recently, I took out all the pin mask wiring for 1-10... all I worry about now is keeping 1st ball, 2nd ball, strike, and foul working... and that's going to disappear soon too. We had lots of wires in our masks... the neon halo lights around the outside of the triangle were still attached to transformers... all of that crap went bye-bye. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
