I have been reading about bowl-tronics solid state sweep and table contactors for 82-70's and tought they sound pretty good but I'd like some other peoples opinons on them before I buy them. you got'em ? how well do they work ? how long they last?
Bowl-tronics solid state contactors
Re: Bowl-tronics solid state contactors
Sean
The SS contactors are great.....we have had a couple in for over 2 years...
No motor coasting.
No points to wear.
No contcactors to fall apart and have the caps blow.
Been testing a pair in one chassis for about three years. No apparent problems. But I have two concerns about them:
1. The 110v goes through an SCR or a TRIAC. These devices can fail either in the open or closed position. Such a failure can probably only be caused by a severe voltage surge. Consider the scenario if your building gets hit by lighteneing or experiences such a severe surge and the triac locks "ON": table and/or sweep continuous run with no interlock protection. Therefore, a word to the wise: turn off your main breakers when the center closes.
2. (82/70 SS or MP) On the original AB or SIEMENS contactors, there is a jumper from the table to the sweep contactor. This equalizes the amperage load coming through the C1 block. Bowtronics supplies only one motor protection circuit breaker for both devices. I'm not sure if this protection works when the jumper is present. I need to investigate this further.
Nevertheless, I'm going with them across the house. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
One other concern...I have seen the table or sweep run with the switch off in the control box. Can any of the electronic guru's tell me why?
Jerry:
Please tell me some more about these SS Contactors. Can they be energized manually? (Like for clearing interlocks?) I was looking at a pic you posted a while back and they do look interesting. I'm tempted to try a pair; only if they can be energized manually.
About you latest post...they can run with the switch off in the BE box. Which switch are you talking about? The Master CB or the individual motor toggles?
Thanks for the info."Where are we going, and why are we in a hand basket?"
They will run with the motor toggles in the off position.
They are available with or without a run switch.
I bought mine without.
I reposted the pic above, however it wont pick up the pic off my homepage for some reason.
