Carpet
  • Carpet
    Has anyone ever done or considered installing carpet on the bins where the heads of the pins rest?
    The bin bumpers suck.
    Possible contact cement or wire ties as a fastening agent?
    Re: Carpet
    Nope, I've never thought about it. But it might be a good idea. The bumpers are turning to crap nowadays. You'd just have to test it and find out. If the pins break through rubber bumpers, who knows what it would do to carpet? Then again it might last forever? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
    You could also think about gluing a piece of distributor belt to it. It might last longer! [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
    Mr. C.
      Re: Carpet
      I like the distributor belt idea. I always keep the old ones to use for stuff like that. I like wire ties better than contact cement because you could remove it easier if you don't like it.
        Re: Carpet
        I know this might not be practical, but, what about self-adhesive velcro to either the carpet or the distributor belt. That way, if it doesn't work, it could be removed pretty easily as well.
        Just a thought...
        Fever [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
          Re: Carpet
          I saw a pic of a '70 bin online somewhere... they used a piece of what looked to be PVC pipe as wide as the bin holder, and cut in half... looked like it had holes drilled into it, and was zip-tied in place through 'em. I entertained the thought of trying it out on a machine, but never got the chance to.
          Probably would be noisier than rubber or carpet, but it would last about forever, and the pins wouldn't drag on it like they do on the rubber pads.
          One of these days I'll get around to it...
            Re: Carpet
            Whatever you try has to be thick so the pin closes the Bin switch. Or just keep using the bumpers in the 9 spot and the big chunk of urethane snap-in pocket rockets in the others.
              Re: Carpet
              I'm going to change my name to "the thread ender" since more times then not the thread seams to end when I post something. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
                Re: Carpet
                False...LOL
                  Re: Carpet
                  jer,
                  ed and i are working on an idea to replace the bin bumpers. i'll keep you posted if you'd like. talk to ed he may want you to test for him, if it goes that far.
                  alex
                  Cloth: ShamWow!
                  Machine: Johnny 5
                    Re: Carpet
                    Thank you,
                      Re: Carpet
                      Tried the carpet and also pin curtain. Not as quiet as bumpers, and do not absorb as much energy, therefore the cradles aren't protected from cracking as with bumpers. But ZOT has replacement cradles for our bins, which have a harder, smoother replaceable plastic insert (one-piece) which really lets the head of the pin slide out easily. Still testing; don't know how long they'll last before cracking.
                      P.S. Absorbing energy also increases stringer
                      life. Fewer "bustouts".
                      P.P.S. The ZOTs are also adjustable, to help if you've lowered or raised your shuttles.
