c ent mech
Re: c ent mech
dane 300,
how do you expect anybody to give you any help when you don't state what type of machines and motors you have [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] do you have 30's or 70's!! and what brand of motors do you have???
and what do you mean cent is on right [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img]
we don't all have espif things aren't going right just use a bigger hammer! DIRT
Re: c ent mech
Originally posted by CUJO:
dane 300,
Charlie [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]Please buy MADE IN USA!
Re: c ent mech
dane300: don't mind CUJO; his bark is much worse, well you know the rest.
Checked your profile and I'm guessing that you have Westinghouse BE motors.
You were somewhat vague to the point that I'm not sure if your sure that you need to change the cent mech.
Pull off the springs carefully or they'll fly across the room. remove collar and legs. mark where the old base is seated and remove it using two standard screwdrivers to gently pry outward. A squirt of lubricant would be nice.
Install: I have a couple different sizes or conduit that I've cut and capped for tapping bearings and cent mech bases onto shafts. Make sure you get the smallest size possible and try not to scratch the rotor shaft. put all the parts back together.
Make sure your terminal board contacts are clean and not arced over. You can file them with a small contact file or burnishing tool. The terminal board is adjustable, if your cent mech does not close your switch, then you can open it a little. Make sure you open both sides and that a gap is the same distance before you opened it.
You just want to bring it closer to the cent mech.
Hope this will get you started
MikePinspotters do not break down when they are not running!
Re: c ent mech
thankyou everyone sorry I did'nt leave more info one gear box went last night I got it runnung today than another gear box on # 4 today they turned it on for 4 th squad of leagues it just buzzed I tried 3 different motors and it did'nt work put I a new gearbox anf ****ed something up with the pin wheel belt it stays on the pulley and pulls the belt in behind the pinwheel only 3 gear box I ever changed the head suposed to be back tonight some time he better huury we need it for glow bowl and I have to go back to work bescause lane 6 will not set any pins up
Re: c ent mech
dane 300,
I knew you didn't have 90's or gold !! you know why? they don't have centrifugal mechanisums!
just something to put in your hat. :p
I just like giving people a hard time like the
king [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] LOL. AND I KNOW HE LOVES IT.
when I was first learning the machines many moons ago I was told to learn all the parts names and electrical functions such as ta1-ta2-sa and so on and what they do so if I ever had a problem and had to call somebody for help I might have a clue of what there telling me to check. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
you still never stated what brand of motors you have? did they come from mexico,china or save on! sorry I gave you a hard time! but I love it.
wake up and smell the coffee or is that the beer! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] CUJOif things aren't going right just use a bigger hammer! DIRT
www.ledsupply.com
www.ledsupply.com
