dist swinging
  • dist swinging
    i found out after almost 3 months of trial and error asking and trying what was causing my dists to swing in certait pin areas ( for me it was the 2-8 pin areas) it was divits under the tube part no. 070-006-004 on the side with the concentric bearing i sanded the divits down and the problem went away just thought yall might want to know ive seen it posted alot but this was never mentioned i never thought to look there because i did not think it had any thing to do with that problem.
    keith [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
    the high tech redneck!!!
    Re: dist swinging
    Keith, I temember someone mentioning damaged carriage tubes. Glad you found the problem.
    You changed your name to keg, I was looking for you. Didn't I read awhile back that you were looking for O-mega Tek schmatics for your chassis? Let me know. I saved some for you.
    Mike
      Re: dist swinging
      mike,
      i still need them and do apreciate your help in getting them for me i sent you a private message with the address
      thanks again,
      keith
