Sure Pik Swinger
  • Sure Pik Swinger
    I had one ball return that would not accept the conversion. It would not adjust out to have enough clearance to let the ball in. If the ball got in...it would roll the belt off at the top. I took the Swinger to a local machine shop and they elongated the holes. I reinstalled the Swinger and it adjusted out ok. If you are having problems with the belt rolling off..have the holes elongated so you can adjust the Swinger up farther.
    Re: Sure Pik Swinger
    I'm waiting for Cujo to reply on this one. :p
      K J;
      I had a swinger conversion that had not been assembled properly. Can't recall what I had to do to it to turn it around-backwards or upside down. Just figured someone from Quality(aka B)control was messen with me. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] :p
      Your Sir Galahad
        KAT,
        what can I say? JERRY RIGG is a sure stuck man and is dedicated to sure stucks! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
        he likes drilling holes in other things in order to get things to work!
        since he painted his sure stucks I thought his stuck problems were over [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] maybe he's just doing a experiment with the swinger!
        I'LL bet he just found that swinger in a trash can at a center near by and decided to give it a try! MR RIGG besides the shuttle tubes how many other things do you re drill the holes in [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] I would like to know how to JERRY RIGG more stuff! do you sell a book on JERRY RIGGING! LMAO your pal CUJO. :p
          Was that post RIGGED?? [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
            Cujo......I need to write a book....
            The Kings Mandates of Bowling Maintenance.
