Dizzy belts??
  • Dizzy belts??
    Has anyone tried out the black belts by lane dynamxs?? They kind of look like the bottom of a tennis shoe tread. A salesman came by with a sample peice awhile back...it looked kind of thick....just wondering if anyone has had any luck with them.....
    Why yes, we wax them everyday!
    Re: Dizzy belts??
    Thick belts are a no-no.
    I like Vantage high grip belts...
    They track great.
    Thick belts track all over the place.....cut through the belt tensioner bracket.
      Re: Dizzy belts??
      Another good belt is the orange rough top belt from Stahl's. It has diamond shaped treads in it. It has a lot of grip and it is not too thick. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
      Louie
        Re: Dizzy belts??
        If the vantage high grip belts are green there Freakin great!!!! Put them on in March of this year and they still wont let a pin slip! They are outlasting the AMF Black top, and the Murray White belts.
        deadwood
          Re: Dizzy belts??
          Deadwood....it is hard to tell but they are dark green.
            Re: Dizzy belts??
            Yup...thats them! Great belts. Although Gates makes a belt that looks the same but its radioactive green. Wonder how that belt performs.
            deadwood
              Re: Dizzy belts??
              If the pics are still on my server, then these should show up...
              Vantage Hi-Grip:
                Re: Dizzy belts??
                G MAN,, Yep! That's the belt that I just started useing. It tracks straight and has enough texture to prevent the wood from slipping. We tried the thick diamond style belt, but they won't track straight.
                Rep. Rob Bishop (R-UT)
                  Re: Dizzy belts??
                  Slow down King &amp; kids;
                  AMF Jeff's question was about the new 'thicky' black belt recently introduced.
                  We ,too, had a rep.(Norm B.from C.B.S.)show up w/ a 'sample' piece of this new dist. belt.
                  My initial thoughts also echoed,"Um,thick belt,I don't know...""but send me one or two I'll try 'em out for 'ya &amp; get back to 'ya."
                  Two show up &amp; I get one installed -
                  Must say,I was most pleasently surprised!
                  GRABBY city comin' off the turn pan(we'll see as oil gathers on belt over time).
                  Tracking;
                  This thick,ridged sucker bearly creeped toward tensioner bracket @ ALL bin locations.
                  My only initial worry;
                  Belt lacings.I really cranked down on those bad boys, but I lack some confidence in their "bite".Time will tell over 6,8,12 months,or more, down the road.
                  We'll see...
                  But for now; thumbs up! ...
                  Fatty
                  fatty
                    Re: Dizzy belts??
                    I have a couple of the Lane Dynamx belts on and they are tracking great. I saw them tested at another center for over a year and there were no problems. There's nothing wrong with a thick belt unless you use the one's from Quality. Those track all over and gunk up the rollers real bad.
                    Pete
                      Re: Dizzy belts??
                      Poplarpetey: now just where might that other center be? LOL [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                      Yeah guys, to back up ol' Petey, we've been testing them for over a year. The prototype was a tad thinner, but the new one performs just as great. Some stats:
                      -Tracks Great
                      -Lasts: after a year, looks and performs 100% like when it was new.
                      -Top stil grippy, but does not mark pins. Lets pins slip just enough during a jam.
                      -Underside is a cloth/fabric material, but the pulleys grip just fine. This underside does not leave any residue on the rollers.
                      -Did not stretch or shrink.
                      -Clipper ends were perfect after a year.
                      I think you can use a regular skiver to remove excess rubber from the top at he clipper lacings.
                      I cut the thinner prototype to 116.5 and 117. Both were fine.
                      The new thicker ones I cut to 117.25. Since the test one didn't stretch, I felt confident that the tensioner would stay put and not hit the casting. So far, perfect. Been running this new one now for about 6 months . . . no problems . . . no changes! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                        Re: Dizzy belts??
                        Thanks for the replys guys....NOOLIO...bowlequip..pete... think i might try a couple....anyone tried them and had "bad" luck?? im curious about the belt strecth factor...after a few years....
                        Worn LBS Rudder Cams
                        Back after 10 years with my mini lane
                        Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
                        The AMF dude
                        Transformer smokes
                        I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
                        Turret 1-7-10 problem
