Here is the deal. 1st ball, bowler throws ball. Table up to 0 down to 320 and stops. Change chassis thinking its a logic problem..problem doesnt move. Replaced motor head, worked for about 30 min then started to interlock.
What gets me is that it only does it during a respot. Not during spot or strike cycle. Before when I had this problem it was a simple case of cut and splice. The power cable comming out of the wireway was old and brittle. Cut and splice and re-wired the plug. Problem went away.
Seems to me that the motor is starting up fine and now just looses power at 320.
Question that just popped into my head while I am typing this post is...could TA be out of adj just a "c" hair?? Flat spot in the TA cam? Only reason I say is cuz the swp stops dead at 66. I know the SC and TB cams are adj correctly. Thats the first thing I checked out.
deadwood
