70 mod
  • 70 mod
    I was out doing a little PR with my customers today and stopped by a center that has 70’s. The mechanic was telling me about a change that he made with the distributors that solved 90% of his problems. Please don’t knock this until you try it because I was blown away with how well it worked.
    He removed the trough that is mounted below the belt just in front of the orientation pan. He left the rod that goes across the frame there but the trough or “pan” is removed. The pins come off the kidney and go right up the distributor. It was probably the best orientation (my pan wipes installed) and pin delivery that I had ever seen on a 70.
    Give it a shot! I think you will be amazed!
    Please buy MADE IN USA!
    Re: 70 mod
    Hmmmmm, I dunno about this one. Please post if anyone here has tried it.
      Re: 70 mod
      Seems to me that tension would be a MUST in this situation. Hmm...im tempted to try this one out right now. I got a dist that is driving me up the wall! If I get done with the Kustodian by 1 I might take this idea for a spin. Geez...never would have thought id like it. Guess there is a first time for everything.
      deadwood
        Re: 70 mod
        I would think thick belts would be a must on this one.........I am a little skepticle on this one......do you leave in the circle tube that keeps the sides on?....what happens when the pin hits the carriage.......heavier pins in the future by ABC mandate?
          Re: 70 mod
          The pin rail and O-pan adjustments are what make great orientation. If those two components are adjusted properly, and kept clean, then you should have no problem reguardless of the dist belt.
          You want them adjusted so head first and bottom first pins come off at the same speed and keep equal distance between all pins.
            Re: 70 mod
            I thought he was yanking my chain also until I actually watched it run. He left the spacers in…just took out the pan. He mostly had the black rough top belts in but I did see a few of the white AMF belts mixed. I was kind of pissed at my self because I usually take my camera out to the centers with me and forgot to grab it when I left. I might have to run out there again next week, if I do I will be sure to get some pics.
            Don’t be so skeptical……I remember the look a lot of my customers gave me when I told them to swap kidneys. [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
              Re: 70 mod
              I have been running them like that for 10 years. It helps to keep the pins from rolling off the side of the distributor. That way you can have the pins fall off the kidney as fast as you want. It works best with the thicker belts, but will work with the thinner ones also. One note: put a 1/4" washer between the center spacer and each of the short outer ones (where the belt runner would be) This helps to prevent over-stressing the side rails when you tighten down the long 1/4-20 bolt that goes through the "tube" spacers.
              Pete
                Re: 70 mod
                Where'd ya learn that one, poplarpetey? (Let me guess)
                PP's right. I tried it just before him and noticed that thicker belts do a slightly better job.
                One additional thing I did: after a few years I noticed a wear spot on the tube that connected the two side rails, so I came up with a simple roller that the belt can ride on. Instead of the long spacer normally used, I used the short tube (with bronze sleeve bushings) and its inner spacer (both used in the tensioner) between the washers mentioned by poplarpetey. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                  Re: 70 mod
                  <font size="2" face="Verdana, Helvetica, sans-serif">Funny you mention the spacer. The mechanic that I met with asked me if I could get them made for him. I have been working with a machinist that cuts plastic and I sent the OEM spacer out to him yesterday to get a bid to have them made.
                    Re: 70 mod
                    When I was reading this I thought "might work".
                    Tried it today on one machine and I think "I'm never-ever gonna put that belt runner back".
                    Thanks for the great tip Sir Charles!
                    Martin
                    So it goes.
                      Re: 70 mod
                      Welcome Beer!
                        Re: 70 mod
                        Hey Bowlequip! That's one you can't take credit for. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] I was runnin' 'em like that before I started working for you. :p [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
                        Pete(PP?)
                          Re: 70 mod
                          OK how about some pictures.
                          You could even include some of this dist. mod. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
                          I would like to see this one.
                            Re: 70 mod
                            The KING decrees this mod is good for his subjects....LMAO
                            I did this mod to lane 10 today.....id does work well.....I will go across the house over the next week or 2.
                              Re: 70 mod
                              What can we make of all those belt runners???
                              Can we make a bigger belt protector of them????
                              To Ed, Pop. and Bquip
                              Martin
                              So it goes.
