I used JB Weld to fix it.
I have also used JB Weld on the other end of the guide wires when the set screw has stripped.
If you are seeing this you are not logged in to Bowl-Tech. Remove this notice by Registering or Logging in |
By your continued use of this site you agree to the following.You are over the age of 18 and have had supervised training in safety and operations of the equipment you work on.Bowl-Tech does not warrant or guarantee the accuracy of information found on this site. Bowl-Tech, its officers, site Admins or Moderators will not be responsible in the case of losses financial or otherwise as a result of use of ANY information on this site. Bowl-Tech is not a substitute for proper training on bowling equipment maintenance. You will seek personal training from trained professionals within your center with regards to safety & maintenance practices while working on bowling equipment. Posts on the site are made by registered members and each member is responsible for the content and accuracy of their posts. |
If you can not agree to any of these terms of use above or are not at least 18 years of age you are asked NOT to visit Bowl-Tech or utilize its content. To visit the Bowl-Tech Terms of Service and Rules CLICK HERE |
