Pins dropping ......
Driving me nuts. 1 or 2 or 5 pin on alley 1, 10 pin on 6, 2 pin on 3. Not always, but way too often. I've adjusted the cups, even replaced one, adjusted spring tension, lubed everything....still persists. What else makes certain pins tip over on 1st ball spot? Pulling my hair out (and I can't afford to do that..hehe)Tags: None
Re: Pins dropping ......
cup gap too narrow, check with guage
x frame pulling away too early, check 1/2 bubble after levelling table and flagging it
basically i would do a full table adjustment, which includes checking all of your cups, cause if your 1 pin cup is out, then you just altered your spot rod adjustment.
do check that your machine is 19" off the pindeck in each corneri don't need mods, i am a bloody genius
In addition, check for warped cups... A cup can have the right gap and still cause problems. Get a 1/8" plate of steel or aluminum (diamondplate works good... use the flat side), or a piece of finished (smooth) hardwood plywood that's about 1" longer and wider than a cup. Run the table down to respot position, and lay the plate centered on each cup. Try to "rock" the plate... if you can teeter it more than about 1/8" to 1/4", the cup will most likely cause wobbly or falling spots.
Cups usually get warped like this from pin jams... a pin falls across a cup, then gets pinched between the bin and the cup edges. After the idiots I mean bowlers cycle the machine a half dozen times before ringing the bell, cups tend to get bent up a bit.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Yes, check for warped cups, they will drive you nuts. And thanks to GMan for the tip, his little tip was mentioned earlier in another post. I think I have a new favorite tool now, definately beats pulling the cup out to check it [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Rep [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]All I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
Hi JC . Where in NY are you located ?
Check the pads in your spotting cups. I have had problems with softer style pads not allowing the pin to slide in , and fully seat in the cup. Also be sure your fingers are adjusted properly. If the fingers do not open properly after a srike , the pins can catch the fingers as the cups turn . MarkThere is light at the end of the tunnel - just be sure it is not a train.
Throw away cup pads or liners....they goo up with todays lane oil.
Jerry"Where are we going, and why are we in a hand basket?"
Try the 090- cup liners. They're black, and they do not gum up. Originally, AMF sent some bad ones out that did not allow clean pins to slide in. Recently, they must have corrected that. No problems.
Vantage urethane (original style, with the pull tips) are also black, and now much better than earlier on. I don't recommend their self-stick ones, unless they corrected them, too. They used to be very sticky.
We still use liners. Been getting the grey urethane ones in from AMF recently, work well. Pins slide well on them, they look like crap after they're in for a while but we've had NO problems with them. Or as posted earlier ya can just do away with em [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
JerryAS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
Its just a personal preference I guess really. If people have problems with the liners they take em out. I've had maybe 5 problems with dropping pins due to the liners in the past 4+ years (we're a 64 lane center, I dont think thats bad at all) and personally I'd rather deal with the very few calls I get and leave em in. But others have a lot of trouble with em and things are fine once they yank the liners. To each his own [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Originally posted by Pin_Head:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 82/70 king:
