foul lights
  • foul lights
    I am using NBI foul lights and a pair doesnt buzz. I need the schematic if anyone has one please let me know.
    Thank you
    Re: foul lights
    If they're retrofits for the 82-120's, your problem can be simple...
    The old AMF buzzers use an AC electromagnet with a little spring-steel plate above the core... If that plate gets bent up or down too far, it won't buzz.
    I like the old buzzers... you can bend the plate slightly to get different tones, from barely audible to obnoxious... [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
      Re: foul lights
      NBI foul light dont buzz, they beep!...im sure youve swapped CB's....check the connection of the orange and blue wires in the plug and to the "buzzer". i swapped out mine for Zots over the past two years. traded them to a guy for motor parts and what not. coincidentally NBI is like 5 blocks away from me
        Re: foul lights
        I have had to replace a couple of speakers. Any speaker will work. An old PC speaker out of a computer works best.
          Re: foul lights
          I have replace the speakers with working ones, that wasnt the problem. I have checked all connections everything seemed tight. I even called NBI they of course wouldnt help me. They refered me to some other local guy up there, but he will not give me any schematic he will fix them if I send them to him. I can fix them if I had the schematic on them. Any help on this would be apprectiated.
            Re: foul lights
            Still looking for some schematics
