i'm new here and i'm french so i hope you will understand what i'm trying to say. my problem is when the table go down there's something that make the motor overheat, any suggestion??
motor
Re: motor
You did not specify the type of machine, but your possible problems may include, a bad motor such as windings or carbon brushes, a bad gearbox, low on oil or a bent shaft in it. A bad table drive shaft causing binding and adding pressure to the motor. If you will add a little more information I'm sure you will get all the answers you need. Good Luck.Without Mechanics Where Would We Be?
Re: motor
yeah Trizac , if possible could you be a little more specific on what its doing like does it overheat after a while, what machines do you have ? does the motor or any part thereof appear to bind when the table runs etc?
p.s. hey gw407 where you are from ... Kissimmee... is that a real place in the U.S ??AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
Re: motor
As for the motor overheating, it could be a bad start switch or Centrifigul Mechanism. If the motor hesitates to start for a second or 2 it can cause a build up of heat. Or, as was said, it could be a binding gear in the gearbox or low oil level.
Louie [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]Experience: Currently Help Maintain 44 82-30s and 50 82-70s.
Worn LBS Rudder Cams
Back after 10 years with my mini lane
Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
The AMF dude
Transformer smokes
I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
Turret 1-7-10 problem
