bad dist. oriantation
hey fellas,I need some help.I have a couple of dist's that give me problems by pins constantly oriantating head first,i've adjusted the kidney a million times still no help,i also tryed raising and or lowering the dist.at the post still no joy.is there any fullproof tricks or im i just overlooking something.Tags: None
Re: bad dist. oriantation
Check your orientor pans, make sure they're pretty close to the pinwheel itself. Should be just enough space so that it doesnt rub the pinwheel. When theres a gap there you'll play hell tryin to adjust the kidney. If that's ok, I'd say keep playing with the kidney and also wipe the o-pan out (in case it's oily, dirty, or whatever) and see what happens [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]All I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
Here is King's Kidney Swap Method:
Originally posted by 82/70 king a long time ago:
1. Take kidney off lane 1
2. Grind Point off kidney
3. Bend down ground off point at 45 degree angle
4. Mount to lane 2 with the top end still up with the rolled edge toward pinwheel
5. Use cushion shock spacers and 5/16 bolts and nylock nuts.
6. Watch FPS # go up.
Have you slowed down your pinwheels? Sometimes that can cause pins to come out head first. I've always thought slowing down the pinwheels was a bad idea. Instead of doing that, all they had to do was make a tackier belt. If you have slowed them down, put the bigger pulley back on and get a rough top belt.
JMO
LouieExperience: Currently Help Maintain 44 82-30s and 50 82-70s.
An ongoing and STILL intriguing thread/post:
What continually keeps me confused isn't flipping odds w/evens of these kidneys.[Got that much]
What still confounds myself(and a couple of others I've tried to make heads&tails about this conversion is):
cushion what shims & 5/16 whats WHERE
Detailed pictures PLEASE!
What replaces those rubber thingies &
Especially how [VISUALLY]!!!
Thanx,
Fatty
Fatty:
Throw the old rubber mounts away.
Use the sleeve inside a cushion shock the xpin goes through fo a spacer.
Use a 5/16 (1/2 head) bolt and lock nut through the sleeve to secure the kidney.
Adjust and go.
JK
