i have seen how lots of you have flipped your kidneys and have done other mods to them. we tried flipping but it only made more problems. so instead, we left them in the original orientation but bent down the top front corner just before the pin drops off into the pan. we had it done in a machine shop, only a few bucks a pop. doing this cured tons of our pileup problems. now we only have a few pile ups due to head first pins, which can be easily cured by a kidney adjustment and about 5-10 minutes of cycling.
Our Rail (Kidney) mod
