quality SSSS
  • quality SSSS
    can anybody gimme the way to rewire the sweep so that the sweep reverse will work with the quality switches?
    i tried doing what the manual said that comes with teh switches but it still wouldnt work
    any help is appreciated thanks
    GOD BLESS THE GREAT WALL OF TOLDEDO!
    Re: quality SSSS
    I have a copy of the booklet with the info at the bowl... if nobody has it handy, I can get it for you. It's just a wire swap in the front channel, takes a couple seconds to do.
      Re: quality SSSS
      If memory serves me correctly.......it matters if you have MP chassis or expander.
        Re: quality SSSS
        Jerry, It matters regardless what chassises you have, unless you want to crank for every OOR...;Wangy call me Monday, and I'll fax it to you...Ex-Mech...
        The 45/70 Goverment is the only Goverment I trust
          Re: quality SSSS
          ex-mech, king means there is a different procedure for SS vs MP machines. ill assume you have SS's Wang. Take red sweep motor wire which goes to
          TSA-2 and put it on TS23
          take the blue wire (l133) and put it to common.
          take the Capacitor wire (#8) and put it where the red wire for the sweer use to be. just see it in your head as a little triangle you have to rotate clockwise <<-- a scary look inside coors mind. if you have MP's ill have to look it up....lol
            Re: quality SSSS
            <font size="2" face="Verdana, Helvetica, sans-serif">Thanks...JK
              Re: quality SSSS
              hey coors
              thanks
              i tried doing it from the manual directions........but i think i took the wrong wire off t23.
              Wang
