On setting up a table today (82-70) I closely followed the manuals instructions. Set up a 5/16ths clearance from table to pin deck, at its lowest position. Put table down to 6 inches of deck and got out my set square. Managed to get half a bubble to the rear of the machine on the spirit level as stated, by adjusting screw (stop). Finally set up respot rod with 1/16ths clearance at stop (when base of pins are 5/16ths away from deck).
All went well untill i did a re-spot cycle on the machine. When the table came down to feel for pins, the cups touched the tops of the pins.
Why did this happen when I achieved all the correct adjustments stated in the manual?
Should I have adjusted the yokes so that the half bubble on the gauge should be facing the front of the machine and not to the rear? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
