Pros & Cons for Omega Tech Chassis
Tech of the Year 2009
- Nov 2000
- 19842
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
Re: Pros & Cons for Omega Tech Chassis
You could probably purchase use SS chassis for $200 or so...that is the route I would go.....then install an Omega Tek board for $150.....you could buy 12 instead of 6.
I have one Omega-Tek chassis in use right now that is trouble free however I agree that you would be farther ahead financially buying some used SS chassis and then buying the MK-70 board to go in them. [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
Worn LBS Rudder Cams
Back after 10 years with my mini lane
Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
The AMF dude
Transformer smokes
I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
Turret 1-7-10 problem
