82-70 dist. overswing
I have a dist.that has just been completely rebuilt every moveable part replaced with new parts now when it goes from the #3 bin to the #2 binit over swings causing the pin to fall on top of the machine side ways causing pin jams not sure what else to do i tried adding another spring but it was too much didnt get there fast enough.......any sugesstions will be gladly apreciated thanks [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]IF IT AINT FIXED YOU PROBABLY BROKE IT!!!!!!Tags: None
Re: 82-70 dist. overswing
1. Distributor post is not level. If it's that wacky, you can probably see the tilt on the distributor.
2. Clutch tension is too tight.
3. Stop blades need some grease.
If it's the latter two, you would probably see double-indexing and jams elsewhere too. Especially at 7 and 10.
Originally posted by Magic Triangle:
Or maybe someone has put a front roller spring on opposite the safety link spring [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] [/QB]
maybe somebody put a spring from the rear roller on! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] LMFAO!
dirtif things aren't going right just use a bigger hammer! DIRT
Dirt, you're a riot! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Seriously, a quick fix, until you can find the problem, is to take a wire tie and squeeze the spring on the back, 10-pin side, maybe 3 - 5 loops of it, together. It will make the swing less severe, and you won't have that pin falling through that empty space.
If the B/E motor weldment is not "plumb", it can put tension on the dist at the "3", and when she "lets go", -sproing-...! We had that problem, and when I jacked up one side of that B/E motor, the problem went away.
A good clue that's the problem, is the dist "wobbles" as it's idling at the "1" pin pocket. I think they all do a little, but if it looks like it moves more than a couple inches, there IS a problem.
Bowl-Tech guys, YOU helped me with that a while back. I hope this returns the favor...if it works...
Doug
If your problem is not solved yet CLICK HERE to get more info on this subject.
Good Luck
MartinSo it goes.
Doug<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
-check to make sure balls of the u-joint are not bottoming out in the horseshoe. (sliding in all the way into and binding against back of horseshoe)
-remove one of the washers off of the ball joints, to make the ball spread narrower
-check horseshoe for groove, apply lots of grease in the horseshoe/balls. [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
LOL [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
Quirky thing, ain't it?
Even a BRAND NEW machine, I don't care if it's an AMF, Via, Xima (sp?), they are succumb to the dreaded 3 to 2 sproing! Lampie, I think it was you, who posted the solution. I had to dig, and sift to find it, but man, it took care of it, and (dropping into Yoda-like voice, the Force strong in this one)..."Grateful I Am, That So Lucid You Are...(echo, echo)!"
Doug
Will.....the problem can also be the pin too close to the trip arm when it moves.....the weight of the pin out that far on the carriage acts like a lever and makes the distributor swing too much.
JK
