PBL help
Re: PBL help
1. Adjust your ball lift to the lowest possible height.
2. Take the spring rod and spring off and replace the spring with a front roller spring and a short piece of chain and a 3/8 turnbuckle from the hardware store....this will apply more downforce.
3. Adjust the spring tension on the ball lift to 4 inches or maybe even 3 7/8.
4. Use a scotchbrite pad on the lift belt.
Re: PBL help
also, need to see where your problem is, the belt or the rails. if the ball is rotating, but not goin up, that tells you the belts doin its job, need some traction on the rails. rosin will help immediately in the short run. ive never tried stahls big tan covers, but i have lifelongs rocket rails <<--awesome
Re: PBL help
solardani, Coors is right, if the ball is spinning you need better rail covers. You can try to flip the lower cover around but if you buy new covers, make sure they are not old models of the same.
Stahl's, Lifelong, even AMF has a new design of rail cover, just make sure you ask for it specifically.
If you try King's rig with the turnbucklemake sure you put a 1/4" eyebolt in the PBL plate.
MIkePinspotters do not break down when they are not running!
