82/70 ss chassis
  • 82/70 ss chassis
    I HAVE A 82/70 SS CHASSIS THAT KEEPS ON BLOWING THE F1 FUSE WHEN YOU TRY TO CYCLE THE MACH I HAVE CHECKED FOR WIRES GROUNDING OUT THE PLUGS ARE FINE.I AM STUMPED I HOPE SOMEONE HAS AN IDEA.
    Re: 82/70 ss chassis
    F1 protects the T1 transformer....
    Good luck.
    JK
      Wrong fuse?(had that once...).
      Will the BE run if you reset your chassis?
      If so, the first 24 V circuit that will be used after you cycle is the sweep relay.
      Good luck,
      Martin
      So it goes.
        We've had a couple like that already... so far, every one I've sent to Stahl's (got sick of fiddling with them myself) came back with the diagnosis of a bad transformer.
        The only other thing I know of that can cause the T1 transformer fuse to overload (other than bridged/burned-out windings) is a dead short in the T1 secondary wiring... it'll cause the primary windings to overload.
          i did replace the t1 transformer and it is good but the f1 fuse still blows when i try to cycle the mach. the backend moter stays runing and the pit lite is on.there is no 1st and 2nd ball lite and i have the wright fuse in it.i still have to check the sweep relay. this has been a pane in the butt.
              </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by buffalojim:
              <font size="2" face="Verdana, Helvetica, sans-serif"></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep.
              Put a new sweep relay in there !!
              Martin
              So it goes.
                Martin
                <font size="2" face="Verdana, Helvetica, sans-serif">Lampie raises a GOOD point there !
                The fuse should be a SLOW BLOW ( 3 AMP from memory on 110 Volts )
                A Standard or a Fast Blow fuse will often Pop immediately as the initial current load is higher than the fuses' blowing current rating ( Usually 25% higher than the Stated rating on the fuse ).
                Slow Blow fuses will have a T ( Time Lag ) designation on them
                Fast Blow fuses will have a F ( Fast ) designation on them
                Standard fuses should have nothing other than Rated Voltage &amp; Current on them .
                Food for thought [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                  i put a new 3 amp slo blow in it and it still blew it as soon as i hit the cycle button.we had a new t1 trans and i put it in but i still blew the fuse.the backend moter stays on. WHAT A PANE IN THE ASS.
                    Under neath the T1 transformer there are three diodes. Change the outside 2. This should take care of the problem. The reason I change both is because its difficult to tell which is the bad one and at less than $1.50 its easier to replace both.
                    David Cliffe
                    Asst. Mgr.
                    Mechanic
                    Youth Advisor
                    Pro Shop Mgr.
                      thank you the power diodes were it. now it is working fine thanks agian for all the help
