What's the best?
  • What's the best?
    Been open 3 weeks now, things are beginning to settle down. I would like to know what are some of the better after market parts that you have found for the 82-70 pinspoters. If you can give me the part number, description and manufacturer. Thanks in advance....Bruce
    Re: What's the best?
    1. Quick disconnect cushion blocks....put them on the non ball door side - Vantage - V203 I think.
    2. Humpback.
    3. Spring loaded paddle shock - Vantage or AMF.
    4. Dist. Belt - EBN Services.
    5. Cushion facing - EBN services - only upper holes showing - no lower rivet head wear.
    6. Carpet belt - Vantage premium or Stahl's tuffy belt.
    7. Lift rod cover - Stahl's.
    8. Sweep Bar - AMF plastic - use the 090 bracket.
    9. Spotting cup - AMF aluminum - NO LINERS.
    10. Rubber rivets - AMF blue urethane rivet.
