Distributer
  • Distributer
    The Distributer sways from the #1 bin to the #2 and #3 bin. Mostly when it is going to the #2 bin.
    these are AMF 8290XL but the 70's do the same thing.
    Has anyone ever ran along this problem?
    I use to grease the balls on the drive shaft.
    Then I went to oiling them and it quit for awhile now there swaying again. So now when I grease them it goes away again. I just go back in fourth grease them and then oil them.
    I also loosen or tighten the clutch spring and that helps also or I add tenchion to the rod safty link spring and or the one on the other side
    With a wire tie.
    Anyone else ever had this Problem and have any other solutions or suggestions?
    Re: Distributer
    Before typing a lot look here first
    So it goes.
      Re: Distributer
      i think ever 70 tech has
      Swaying at the #2 bin is usally cause by a dirty or to tight clutch
      it can also be caused by the distributor post being on a lean
