82/70 sweep runs over pins
  • 82/70 sweep runs over pins
    we have the one piece amf sweeps,and if there are three or more pins in one gutter with the heads of the pins facing forward the sweep runs over them and throws them back out. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
    we get a bunch of dead pins in front of the sweep.
    what needs to be adjusted to stop this stuff.
    we get a bunch at times. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
    KEN.B
    Re: 82/70 sweep runs over pins
    ken, we get that a lot where I work also. The sweep height at the 5-pin line is what ya need to check. I believe it's supposed to be 1/2 an inch if my memory serves. I know where I am some are adjusted even lower than that and it still spits pins. We have some of the new sweep brackets on order that do away with the slide bar, I heard this also helps lessen deadwood calls so we're gonna try a few and see how they work. Anyway, make sure your sweep height at the 5-pin is right though. Thats the place to start! Hope this helps [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
      we have the new single piece sweep hanger brackets on several machines and they do help reduce deadwood being kicked out a lot. since there is no slide bar the sweep is able to run through and sweep the pins in the gutters with a little more "down force"-you should try those it should make a big difference
        TABLEJAM, thanks for the info. I've heard good things about them. I think we have 2 lanes worth or so on order. Looking forward to getting them in moreso now [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] I like the nickname btw hehe [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
          You need part #
          090-001-171 LH
          090-001-170 RH
          The NEVER break and the slide bar assy is done away with.
          JK
            Those are the ones we ordered King, if you say they're good I trust ya [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
              thanks for the help. I'VE asked a few other mechanics and they said the newer sweep are lighter compaired to the older ones with the bars
              and that's the main reason they run over the pins more often.
              we ordered some of the newer brackets and are going to give them a try.
              KEN.B
                ken, yes indeed. the new sweeps are a good bit lighter than the old style. I like them better but they did increase our deadwood calls quite a bit since they were installed. I'm hearing very good things about the new brackets so maybe they'll be our answer [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                  I believe the height adjustment calls for 5/16 clearance. I have a few lanes that are maxed out and are still way higher than that. Is the frame height off? I want to get them evened up and at the right height. When I get back working full time again, I'll be sure to have more sweep questions.
                  Charley
                    Farley, check to make sure the knuckle that comes out to adj the height at guard is as level as possible, if its not (as some lanes were where I work were) you wont be able to get it adjusted, it'll either stay too low or high depending on if it's up or down. Level that as best ya can then try and see if your adjustments work [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
