C-1 Plug
  • C-1 Plug
    When I came back off of vacation my C-1 plug was tore apart at the terminal trips. 5 wires were pulled. Does anybody have a good schematic to tell me where these wires go back??
    Of course no one here knows who pulled the wires. It was like that when I got back here they said???
    Thanks
    You can email me at jimmy@thebowlingalley.net
    Re: C-1 Plug
    All of that is covered in the 5500 prints. I've got a set, but is is way too large to scan or fax. Just post which wires in the C1 are missing/disconnected and I'll tell you where the print says they should be.
      Re: C-1 Plug
      Kat,
      The wires disconnected are DD,FF,JJ,BB
        Re: C-1 Plug
        Originally posted by jandlcox:
        Kat,
        <font size="2" face="Verdana, Helvetica, sans-serif">DD should terminate on TSA-2
        FF should terminate on TSE-2
        JJ should terminate on TSA-3
        BB should terminate on TSE-1
        Good luck and hope this helps.
          Re: C-1 Plug
          Thanks,
          going to try it now, where did you get your schematic from, I need one and AMF doesnt have what I need they said, anyway
            Re: C-1 Plug
            You're welcome.
            Use part no 610-007-030 to get a folder of a bunch of different prints. Very useful...
              Re: C-1 Plug
              Do you have any idea what the tse1 and 2 do I dont have any other wires on the jumper on any of my machines??
                Re: C-1 Plug
                <font size="2" face="Verdana, Helvetica, sans-serif">TSE-1: Contains wire BB from C1 &amp; Wire to Sweep Motor Plug "Z"
                TSE-2: Contains wire FF from C1 &amp; Wire to Sweep Motor Motor Plug "Y"
                I've seen many installations where they bypass the terminals in the wireway for these 2 connections. Instead, they will use a butt-in splice to tie the wires in directly. Either way, just make sure the C1-BB ends up to SMP-Z and C1-FF ends up to SMP-Y some how.
                  Re: C-1 Plug
                  got it thanks alot for your help
                    Re: C-1 Plug
                    <font size="2" face="Verdana, Helvetica, sans-serif">Anytime. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
                      Re: C-1 Plug
                      Who tore the wires out.....they would be history [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img]
                      JK
                        Re: C-1 Plug
                        There are getting ready to be history!!! I think it was 2 of them
                          Re: C-1 Plug
                          They most likely hid your schematics too.
                          Go to another 70 house and take their schematics to a copy shop; have them copy and laminate what you need.
                            Re: C-1 Plug
                            does aaron the "anti-mechanic" work there?
