Hi,
The balls will ride againt the cushion in the corner on the ball door side.
Anyone else have this problem?
In the past I have replaced the old worn rubber rivet in the bottom corner with AMF urethane rivets and it took care of 98% of those stops.
I now have one machine that has this problem again regularly. It has the urethane rivet even changed out the cushion assembly. No Different
No obvious bounce plate problems
Does any one have any other solutions that you have found?
