New product idea
  • New product idea
    Vantage, Stahl's, Eddog, AMF, VIA.....
    I have a fix that plagues 70's.
    Many times the rear pins will not go on spot even with the table flagged and as far to the rear as it will go.
    My fix is to take the spotting cup cap and cut the keyway where the shaft key goes in and cut the groove 10 degrees off parallel to square on the modified cap.
    This will allow the cup to have more rearward adjustment......the longer cup bolts do not work.
    JK
    Re: New product idea
    i have found that when my rear line of pins are difficult to adj to spot.
    i check that the table yoke (X frame) is centred with the 1 and 5 pins.
    makes a hell of difference.
      King please post a pic of this I would like to see it. This is one of those times where I need a picture painted. Thanks
        Hi MOnkey Boy,
        Who are you and where are you?
        Len.
        Regards,
        Len.
