I have a lane that when the 3116 rod and the 3162 rod are set to the proper adjustment the rocker arm (070-003-132) is hitting the table gear box hard enough to make the table jump.
In order solve this and have the sweep rocker arm not hit that table gear box and the sweep knocking the back row of pins off ….. I have to have the 3162 rod almost an inch to long and the two 3116 rods are short adn somehow not even length. Another strange thing is that when I have this adjusted so it will work the ten pin side sweep shock is over extended making that side of the sweep raise way off the pin deck. The links are also hitting the machine frame pretty hard. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
The last thing is that the table drive shaft has been replaced several times and the sweep rocker arms have also been welded. Now i guess I know the cause of the table shaft breaking. The shaft is sitting straight for the table drive and the welds appear to be straight on the rocker arm.
Any ideas about this???
