Pindication...help me thru this PIA !
  • Pindication...help me thru this PIA !
    SS chassis..omega-tek boards. I have 2 chassis that have 1st & 2nd ball lights & strike..but no pin lamps.Assuming the Omega-tek is ok.... Most components are bypassed by the Omega-tek,right ?
    I have 2 others that are missing just one lamp.
    Thanks !
    PS I haven't switched out the omega -teks yet..that's next.
    Re: Pindication...help me thru this PIA !
    Check the diodes or resistors between the PM plug and the 5 board slot on the mother board.
    JK
      There are two ground/neutral wires, one handles 1ball, 2ball, & strike... the other handles pinlamps 1-10. Since all the lights are not working, start from the common factor first, then work your way out.
      I'm gonna throw a stupid one in here:
      If this is a problem that just recently happened on boards that did have pindication, skip this comment... but if they were just purchased or just pulled out of the box, check what type of Omegaboards they are... O.T. did make Omni's that did not have pindication.
        GEEZ !!
        I have a chassis that still had the 5 boards in it...it HAD 1st ball &amp; 2nd. ball lights,but no pinlamps.
        Without removing the C1,C2A or PM plug,( just pulled R/S plug), I installed a WORKING Omega -tek( from another chassis that all light worked).
        Now,I have pinlamps but no 1st or 2nd. ball lights [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img]
