machine starts to spot pins and as soon as the 9 pin leaves the 9 pin lever table stops [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] if the lever is pushed and held in the table will continue to spot,if you let off the lever before the pins hit the deck table stops,after the pins are on the deck the table will continue back to zero without holding lever.
first thing I changed was spotting relay,still the same?
2nd changed the omega tek board-still the same?
changed the chassis [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img] still the same.
changed the bin switch-still no good [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
so in order to be able to use the machine I duct taped the lever open [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] now it sets pins every time ready or not hear I come. :p
any ideas what is causing this.
