82/70 omega tek. sweep does not stop at 270,just goes to zero and stops.
it does not cause any problems unless the bin is not full,and the bowlers push the reset button at right time then it will interlock.
if the cycle button is not pushed,as soon as the 9 pin goes in it sets pins with the sweep up. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
changed chassis--still same,adjusted sa, then replaced the switch! still no good.
any ideas,thanks
