rh-rh lh-rh lh-lh lh-rh
  • rh-rh lh-rh lh-lh lh-rh
    This is for 82/70's
    I got tired of figuring it out every time
    What you think, eh?
    Right-Hand Machine (Odd Machine)
    070 011 642 Urethane Ball Door Weldment
    610 704 043 60HZ Westinghouse Backend Gearmotor
    610 704 047 60HZ New Vantage Backend Gearmotor
    000 022 080-111 Red Lightning Kicker Roller
    000 024 796 Wood Cushion Plank
    000 024 807 Cushion Assembly – Premium Cushion
    030 002 792 82/30 Hanger Weldment
    070 002 050 82/70 Hanger Weldment
    070 002 060 Cushion Assembly – Total Cushion
    000 023 465 Support Weldment
    000 023 431 Clip Bottom
    000 024 508 Pin Ejector Assembly
    000 024 513 Spring – Pin Ejector
    000 024 624 Rear Segment - Kicker
    000 024 625 Front Segment – Kicker
    070 011 006 Door Weldment – PBL
    000 021 420 Bounce Plate Assembly
    000 029 899 Bounce Plate – Front
    000 029 924 Bounce Plate – Rear
    000 024 811 Ball Return Pulley 5”
    000 028 772 Ball Return Pulley 4”
    000 021 407 Idler Arm Assembly – Kicker
    070 011 406 Rudder Cam Weldment Assembly – PBL/LBS
    070 006 101 Distributor Drive Shaft
    070 006 102 Distributor Drive Shaft Assembly
    070 002 004 Arm Assembly – Carpet Drive
    785 501 177 Gearbox Housing – Westinghouse
    785 501 124 Offset Output (Bull) Gear
    785 501 132 Pinion Gear
    785 501 147 Wheel Gear – G.E.
    785 501 431 Worm Gear – Westinghouse
    785 501 434 Wheel Gear – Westinghouse
    Right-Hand Side of Any Machine (10 Pin-Side)
    000 022 794 Urethane Cushion Block
    300 000 170 Sweep Mounting Bracket – Plastic Sweep
    610 700 079 Shield – Metal Sweep
    070 003 190 Shock Bracket – Sweep
    070 006 388 Track Assembly – 1 Pin Bin
    070 006 376 Stringer Outside – Bin
    070 006 369 Pin Guide (outside wall of bin)
    070 006 015 Trip Arm Assembly – Distributor
    070 006 104 Support Guide – Distributor
    Left-Hand Machine (Even Machine)
    070 011 641 Urethane Ball Door Weldment
    610 704 042 60HZ Westinghouse Backend Gearmotor
    610 704 045 60HZ New Vantage Backend Gearmotor
    000 022 080-112 Red Lightning Kicker Roller
    000 024 795 Wood Cushion Plank
    000 024 808 Cushion Assembly – Premium Cushion
    030 002 793 82/30 Hanger Weldment
    070 002 252 82/70 Hanger Weldment
    070 002 260 Cushion Assembly – Total Cushion
    000 023 464 Support Weldment
    000 023 432 Clip Bottom
    000 024 507 Pin Ejector Assembly
    000 024 512 Spring – Pin Ejector
    000 024 623 Rear Segment – Kicker
    000 024 626 Front Segment – Kicker
    070 011 005 Door Weldment – PBL
    000 029 656 Bounce Plate Assembly
    000 029 926 Bounce Plate – Rear
    000 029 925 Bounce Plate – Front
    000 024 812 Ball Return Pulley 5”
    000 028 773 Ball Return Pulley 4”
    000 022 218 Idler Arm Assembly – Kicker
    070 011 407 Rudder Cam Weldment Assembly – PBL/LBS
    000 024 893 Distributor Drive Shaft Assembly
    000 022 369 Distributor Drive Shaft
    070 002 216 Arm Assembly – Carpet Drive
    785 501 178 Gearbox Housing – Westinghouse
    785 501 126 Offset Output (Bull) Gear
    785 501 131 Pinion Gear
    785 501 146 Wheel Gear – G.E.
    785 501 430 Worm Gear – Westinghouse
    785 501 439 Wheel Gear – Westinghouse
    Left-Hand Side of Any Machine (7 Pin-Side)
    000 022 795 Urethane Cushion Block
    300 000 171 Sweep Mounting Bracket – Plastic Sweep
    610 700 089 Shield – Metal Sweep
    070 003 191 Shock Bracket – Sweep
    070 006 386 Track Assembly – 1 Pin Bin
    070 006 377 Stringer Outside – Bin
    070 006 370 Pin Guide (outside wall of bin)
    070 006 103 Support Guide – Distributor
    Left-Hand Side of Right-Hand Machine (7 Pin-Side, Odd Machine)
    070 007 373 Pit Support Bracket
    000 027 645 Bearing Support
    000 027 368 Plow – Large
    Left-Hand Side of Left-Hand Machine (7 Pin-Side, Even Machine)
    070 007 374 Pit Support Bracket
    000 022 249 Bearing Support
    070 002 169 Plow - Small
    Right-Hand Side of Right-Hand Machine (10 Pin-Side, Odd Machine)
    070 007 372 Pit Support Bracket
    000 029 672 Bearing Support
    070 001 412 Plow - Small
    Right-Hand Side of Left-Hand Machine (10 Pin-Side, Even Machine)
    070 007 375 Pit Support Bracket
    000 027 646 Bearing Support
    000 027 372 Plow - Large
    Re: rh-rh lh-rh lh-lh lh-rh
    An excellent beginning. We just need to keep bumping it forward.
    One of the nice things about working on 82-90s is that there is only one platfom support brace for both sides of both machines.
    Roger
      What you think, eh?
      <font size="2" face="Verdana, Helvetica, sans-serif">Look's great except for the "V" in front.... [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
      Please buy MADE IN USA!
        Thanks.
        JK
          Thanks for the list MT. Just saved it to print it!!
            This helps thanks! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
              Bump!
              <font size="2" face="Verdana, Helvetica, sans-serif">FIXED!!!
              Unfixed: I just realized the yoke springs
              070 002 688
              070 002 689
              are missing from the list - but it's not as simple as it looks. I remember something about them having the "wrong" name because they're named after the way the spring is wound rather than their position on the machine. Or maybe that was some other spring.
              Anyway, can somebody check this out and classify them properly?
              And if you can add 30- and 90- specific parts too, that'd be swell!
              Thanx, C
                You mean to tell me you guys don't know those numbers by heart? [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                  Very nice Ramblerman.
                  Guess this answers the question of what you did to pass the time during your Bowl-Tech "vacation". :p
                    I'm L.H.
                    I'm R.H.
                    I'm L.H. for R.H.M.
                    I'm R.H for L.H.M.
                    We like to smash some fingers(R.H an L.H.)
                    What are we ???
                    So it goes.
                      can somebody pull back this front roller hanger and release my haaaaaaaaaand please.
                      maister
                        [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] You are THE Maister!
                        So it goes.
                          Nice. I printed a copy and will check it over.
                          Mike
                            nice light hearted bit of fun Lampie.
                            maister
                              what about the clips for the large plows? If the odd machine is the LH one and since the large plow in on the LH side of that machine, shouldn't the clip be specified as clip LH? in the parts book it is RH and it says the LH clip goes behind the large plow (which would be on the right side) of an even machine- which would be a RH machine.. are these listed backwards? can somebody check this out?
