Spikewiz
Humpback Ball Lift System - need your feedback!
Tech of the Year 2004,2008
- Jun 1999
- 4204
- A- 2 / 8270
- Qubica / Frameworx
- Phonix-S / Kustodian
- Prolane / HPL / SPL
- 1983
Tech of the Year 2009
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- Phoenix S & Walker
- Brunswick Pro Anvilane
- 1982
Re: Humpback Ball Lift System - need your feedback!
I have had them operational for 3 years.
The Humpback is great.
Ball call elimination.
Here are the King install tips:
1. Use stover lock nuts rather than the nylock nuts supplied.
2. Use grade 8 bolts rather than the soft grade 2 supplied.
3. Install the lift are without bending if possible.
4. Install lock nuts on the ball lift height bumpers for the proper adjustment.
5. Do not use any Vantage clutch pulleys....the v belt will slip inside the groove due to pressure lifting some heavy resin balls.
- Nov 2000
- 19908
- AMF 82/70
- AMF Accuscore +
- 1982
Originally posted by Herbert E.:
Can anyone give me some feedback on the Humpback ball lift system? How well does it work, installation problems, does the system hold up well, cost or any other pertainate information.
Spikewiz
JK
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
