Cups hitting bin!
  • Cups hitting bin!
    In the process of going through all my tables at present. Have come across a machine were the table is set at the correct 5/16ths off pin deck height, but at zero degrees the cups are touching the bin! Table legs are also battering off the cat walks!
    Have raised up the shuttle but still get interference. What is the best solution to this problem?
    Should I raise the front part of the machine by adding in big washers to the bolts, attaching it to the kickbacks? or should I raise the table by adjusting the table post legs, then lower table with the clevis adjustment? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
    Whats the best way to do this?
    Are there any specific measurements for this?
    Re: Cups hitting bin!
    Has anyone lowered the bin hanger brackets?
    Rep. Rob Bishop (R-UT)
      I have seen guys use the countersunk washers (that are used for the cushion bolts), drill them out and put them under the bin brackets to raise the front of the bin and of course the back already has bolt holes to be raised as well.
      I haven't run into this problem yet but have helped guys through this. Our symptom was the shuttle hanging up on the cups during shuttling.
      Mike
        <font size="2" face="Verdana, Helvetica, sans-serif">I've cut about 1/2" out from the middle of bin hanger bracket , then welded the remaining two pieces back together. Had to do this because the lanes had been resurfaced 21 times over the years and the space between the table and the shuttle became to wide , sometimes letting a second pin to " double shuttle " This was much easier than lowering the entire machine. Only had to do this to the front two brackets because the rear ones could be adjusted by lengthening the rods.
          All of my machines have had the bins lowered to reduce the distance between the cups and the shuttle. We re-drilled the bracket holes and bolted them back up.
          I don't understand why you would remove a section of the bracket. That would make the bins higher and the distance between the cups and the shuttle greater. Did you add a section to the hangers?
          Did the lanes change, forcing you to re-hang the tables further up?
            Is your sideframe height @ 18 7/8" at all 4 corners (7 pin front, 7 pin rear, 10 pin front, 10 pin rear)?
              unsure. Will measure heights next time im in.
              Cheers talkintrash! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                With a little investigation, have found that the bin had been put back together in the lower posistion. Obviosly a tech who had to change a bin part couldnt be bothered to built it together correctly and just positioned it in the lower position. Raised bin up and bobs your anty! problem solved.
                  Congrats, Alastair! Usually, if it's only one machine, the problem is within that machine and not with the lane/machine height relationship.
                  Let's all keep in mind, though, that the height of the front end unit is critical, although you do have some latitude on the specs. If a machine is too high due to years of sanding, you've got more than just table-to-shuttle issues. What about the sweep? Just lowering the bin/shuttle assembly will not do anything for the rest of the machine. The front end unit MUST be lowered once you reach 19-1/2" from the bottom of the lower frame member to the pindeck. Otherwise your problems may also include inability to lower the sweep bar sufficiently to sweep multiple pins out of the gutter, and loss of spotting hook uo front due to inability to move the table far enough back on its supports. In short, you'll run outta adjustment all over the place!
