I have watched these machines when this happens and I have noticed lots of sparkage in the sweep and table motors when they engage and that some have a tendancie to roll after each stop just a hair but enough to make say the sweep hit the head pin or just go right through and sweep out everything. So the question is, are these motors bad, can I rebuild them, or should I be lookin to replace these motors? Or am I lookin in the wrong place for this problem? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] Thanks in advance.
sweep & table motors?
Ok Guys heres a question for ya. I have a few machines that radomly run the sweep for no aparent reason and a few others that tsi radomly.
I have watched these machines when this happens and I have noticed lots of sparkage in the sweep and table motors when they engage and that some have a tendancie to roll after each stop just a hair but enough to make say the sweep hit the head pin or just go right through and sweep out everything. So the question is, are these motors bad, can I rebuild them, or should I be lookin to replace these motors? Or am I lookin in the wrong place for this problem? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] Thanks in advance.beware of attack mechanicTags: None
Re: sweep & table motors?
Westinghouse, GE, National ?
The motors do have centrifugal switches that can be replaced.
Bad motor capacitors ( in the wireway ) could also make a motor coast , or overheat.
The sweep and table motor contactors in the chassis could be burned. The cam micro switches could be bad. What kind of condition are the C1 plugs in ? Personally, I would start swapping good motors on the machines with coasting problems to see if the problem moved with the motor. National motors have carbon plugs that act as a brake. When they get worn down, the motor will coast bad, especially on the table.
Lastly, what is tsi ?
MarkThere is light at the end of the tunnel - just be sure it is not a train.
TSI is table sweep interlock, where the table comes down on top of the sweep while the sweep is in motion and it creates a jam up that can only be fixed by cranking table up and sweep back to zero manualy. Most of our motors are Westinghouse I believe some are different but the ones I was refering to are westing house. We did some minor cam adjustments today that seems to have at least momentarily stop the sweep hitting the head pin thing. Maybe I will start rebuilding some of the real bad ones.beware of attack mechanic
Interlock is controlled through TA3(TB) and SC.
If it seems like the motors are drifting, it could be the lower contacts on the contactors... the lowers control dynamic braking of the motors. The gearboxes and rotors need to be tight and not sloppy, or they'll cause drift.
Other than that, I can't help ya much... we run National motors. Never really ripped into GE/West. stuff.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Hmmm.
You might remove the gearbox and check for worn splines on the gearbox output shaft &/or sweep shaft.
Finding that OK, you might then remove the flange from the gearbox and find wear on the ring gear or helical gears.
You might also be able to demonstrate slack by stopping the sweep around the 4-5-6 line and pushing/pulling on the crank arm.
Typical to cause the sweep to be slightly out of time when it stops at 1st guard, toward the back of the deck, and again at 0.
Good luck!
Chad
